Can you provide examples of vehicles that can have the computer reprogrammed to charge AGM OR FLA batteries?AGM batteries are about all I use in my equipment. I have always used Yuasa batteries for they seem to last longer than other brands.
A lot of the charging problems comes from people that puts an AGM battery in a modern car or truck that had a wet battery. The computer is not programmed to charge them correctly. But the computer can be reset to normal and safely charge AGMs by any good mechanic. Also charging them on a system that produces more than 14.2 volts is not good for them either.
Another mistake people make with AGM batteries is not following instructions. If you order one online. It will come "dry" and need acid added to it. Yuasa motorcycle and ATV batteries come with the correct amount of acid. Do not add any more than it calls for. Also let the battery sit for at least 24 hours to give the acid time to fully soak into the mats before you connect it to the charger for the first time. Let it fully charge before putting it into service. Skimping on those two important steps and the battery life will be greatly diminished.
