BarnyardEngineering
- Location
- Rochester, NY
The fitting came loose on the hose that goes between the left and right lift cylinders on the Gehl 2350 (Vicon 281?) discbine. Now the right side is hanging low and won't raise all the way, even after several cycles.
I figured it would work like the cylinders on the corn planter where the oil works its way across through a small hole and things would even out. No such luck.
Bleed the air I guess?
