Anonymous-0
Thought about adding a relay off my light switch to keep from burning up the switch when I haul my trailer at night with all the running lights going. My question is in the wireing of the relay switch 1 wire from batt.,1 ground,1 from light switch not sure about that . Do I just cut the wire at the light switch and connect both cut ends to the relay switch like one wire will feed in and on the other terminal connect the other end to relay terminal which would be out to the lights?
Thanks In Advance for any advice Mark
